Electric fan
Old Dec 2, 2008 | 10:14 AM
redmann's Avatar
Electric fan
I'm having a problem with the fan. It would come on when the temp reach 190 degree, but now it comes on as soon as you turn the switch, and I'm not getting an error code. I change the fan relay but that didn't work
Old Dec 2, 2008 | 11:08 AM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Re: Electric fan
ive had that same problem but i did mine on purpose as soon as the key was on the fans turned on and the way i done that is by a ground off the cooling fans i just took off a ground not sure wich one id have to check my diagrams
Old Dec 2, 2008 | 07:55 PM
3colored 92 RS's Avatar
Car: 92 RS Camaro - 25th Anniversary
Engine: 3.1 V6
Transmission: I dont know. Its an automatic! LOL
Axle/Gears: Dont know, but has CENTERLINE RIMS!
Re: Electric fan
Ohhhh Maaaann! Be my HERO. Im having similar problem. Could use all help.
1992 Camaro RS V6 Auto 3.1L 269,000miles
4 days ago just happened to look at dash, and temp was at 210. max temp on gauge is 260. car runs normally at 180 w/o any type of cooling prob.
over last 3 days i let it idle from a complete cold start to normal running temp (180) checking for the fan to come on. Fan failed both times.
thermostat is good. oil pressure is good. alternator & belt are only 3 wks old. batt is fine. think my solenoid is dying. hoping it hangs in til after holidays.
not sure if i did jumper wire test correctly, but the fan motor plug in made the light bulb come on inside the test light i used. and i dont know where to find the fan relay or what else to test. Please tell me where to look and i will get on it.
figured out what master cyclinder is, & tried again to find fan relay, but im still not sure. i need help.
dont know if this is related to my problem, but ....
i checked the fuses, ALL of them. ACC was blown(25) replaced it, blew again. replaced again, blew again. replaced w/ lower fuse (20), it blew.
this was all within 5 mins. i connected /disconnected the neg batt each time
any explanation you could give me would be great. tell me some details too, because i dont have a chilton. thats a whole other story!!! LOL
Thank you, Kimberley. (will check back 8-9pm pst)
Old Dec 2, 2008 | 08:06 PM
Engine: 3.1 V6
Re: Electric fan
Sorry Sorry Sorry Sorry Sorry Sorry Sorry Sorry
i didnt mean to use reply to actually make a post on your post. but it sure looks like i did. i apologize. this is my 1st day here, and it was an accident.
will post it in proper place....... ty
~~kimberley~
Old Dec 2, 2008 | 09:40 PM
Ironman0423's Avatar
Car: '89 Camaro RS
Transmission: auto
Re: Electric fan
ya i have the same problem i turn on the key and the fan comes on. i ve blown many relays and fuses and cant figure it out. sorry i cant help man. so any help is appreciated.
Old Dec 3, 2008 | 10:29 AM
redmann's Avatar
Re: Electric fan
I don't have the answer, but I'll let you know as soon as i do. Thanks
Old Dec 3, 2008 | 10:35 AM
redmann's Avatar
Re: Electric fan
~~kimberley~
I don't have a clue, if I find out something i'll let you know
Old Dec 3, 2008 | 10:43 AM
redmann's Avatar
Re: Electric fan
I was told that's not good because those electric fans will burn out. I use to drive my car to chattanooga all the time, until that happened. You need to buy the book "Chevy TPI Fuel Injection Swapper's Guide" by John Baechtel. Try books a million or Barnes and Noble, you may have to order it. It's well worth $20.00
Old Dec 3, 2008 | 02:58 PM
87transGTA's Avatar
Car: 87 GTA
Re: Electric fan
well with your fuses blowing that quick you have a short somewhere check your cig lighter you might have something down in there, sometimes pennies or anything in that matter gets stuck down there causin the fuse to blow, now on your fans you might have a bad relay as you said now i can email you a picture of the engine bay and shows where all the relays and switches and i guess just go and check off one by one might just end up being a bad temp switch, you also might want to check in the back of the fuse panel to make sure all the wires are making good contact to the fuses. if you have any other questions feel free to message me
-Eldin
yeah that was one of my worries about the motors blowing i have diagrams and i also have a shopkey5 account and its basically a chiltion manual online well actually its ALOT better i live out in chattanooga hahah, i just re-wired my fans to switches one for each fan. I might go out tonight and check out that book thanks
-Eldin
Old Dec 3, 2008 | 03:15 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: Electric fan
Do you have dual fans or the single fan?
My aux fan (pass side) was staying on like that and it turned out to be the switch in the passenger side head. I replaced the switch and now it works normally again.
Old Dec 3, 2008 | 03:24 PM
Engine: 3.1 V6
Re: Electric fan
-Eldin
-Eldin
Hi, on my way outside to check my cig lighter.... would appreciate the email Eldin. send here.... ki_anme@yahoo.com
~~kimberley
Old Dec 3, 2008 | 04:00 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Electric fan
Find anything in the Cig Lighter ? Did the previous owner rewire the fan ?
Old Dec 4, 2008 | 05:33 PM
Engine: 3.1 V6
Re: Electric fan
THANK YOU. i disconnected the cig lighter. and now i have a horn, interior lights, a under the hood light. and that means my ACC fuse is not blown now. very thankful. HOWEVER, i havent been able till now to say thank you cuz i was visiting my gramma. please email the fan relay location so i can get on that. thank you
~~~Kimberley
Old Dec 6, 2008 | 11:00 AM
87transGTA's Avatar
Car: 87 GTA
Re: Electric fan
~~~Kimberley
hey Kimberley, your very welcome , i sent you an email sorry i didnt get to it earlier ive been busy with my ride ive been havin transmission problems well its either trans problems or engine.
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
