THERMOSTAT LOCATION
Old Dec 10, 2008 | 06:03 PM
wano1147's Avatar
THERMOSTAT LOCATION
With a reverse rotation water pump cooling system where the cool water goes to the heads and then the block and hot water out the water pump back to the radiator, wouldn't it be better to have the themostat in the lower radiator hose at the water pump exit? Seems like the motor is always going to be hotter with the cool water from the radiator going to the thermostat.
Anyone have any thoughts on this?
Old Dec 10, 2008 | 06:13 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: THERMOSTAT LOCATION
one would seem to think that, your water would be its coolest at the stat, instead of its warmest at the stat, so i agree with you i think it would be better at the bottom, but the people i know running a reverse setup are also not running a stat, maybe a water restrictor
i havent seen a stat houseing you could put after the pump, that would let you run this kinda setup
i want to see where this goes, id like to see other thoughts, i been thinking of going reverce flow
Old Dec 11, 2008 | 12:13 PM
wano1147's Avatar
If you have a 1989 5.0 camaro, you already have a reverse flow system.
Old Dec 12, 2008 | 08:47 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Thats not what it does at all, the reverse rotation is only referring to the pump itself, not the way the water flows, its still being sucked from the bottom passenger side of the radiator thru the pump, block, heads, intake, thermostat, then back to the upper driver side radiator, in that order.
Old Dec 12, 2008 | 09:05 PM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
Old Dec 14, 2008 | 04:50 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
the pump is reverse cause the serpetine belt spins the pump backwards till flows the same way as a v belt setup
Bubbajones_ya
Jul 6, 2024 08:32 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
