Fans won't come on
Old Jan 17, 2009 | 04:51 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Fans won't come on
Recently the cooling fan on my 91 RS quit working. The temp sensor for the fan broke off so it won't come on over 220. But I could still turn on the A/C and the fan would turn. Now it won't come on at all, even running the A/C, and there is no power to the plug going to the fan at all.
Any help would be appreciated.
Old Jan 22, 2009 | 08:20 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: Fans won't come on
That would be your temperature fan switch located on the driver side of the motor. should be a green wire going in to it, and i believe it screws into your head. be careful coolant will come out when your taking it off. mine did that to me before also so i've been through all of that bs.
Old Jan 26, 2009 | 11:35 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You won't have power to the plug on the fan unless the ECM tells it to turn on. The reason it came on with the AC on is because the fan is designed to run with the AC on. Would need to know more info to see why it might not be working now. Either way, Replace the temp sensor and related connectors and all should be well. Or at least better than it is. Hopefully.
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
gta892000
Sep 16, 2015 12:37 AM
