Need help locating this coolant tube
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
So I would like to buy a replacement coolant tube for my iroc. This part is located on the passenger side rail. I have not been able to find it and I'd like to get a new one rather than a used one if I can avoid it. If anyone has any info on this piece, I'd appreciate it. Thanks
Will
Will
Re: Need help locating this coolant tube
You have a couple options, local I would try NAPA. When Auto Zone, Advance, and O'riley's don't seem to even know what parts like that are, NAPA has them or can order them.
If they don't have one or can't get one, you may try something like Hawks, Year One, I think Classic Industries has 3 gen parts too, but don't quote me on that one.
If you can find one, and you have a welder you can get a piece of aluminum or brass tube and bend it to that shape, and weld/braze the t in, or see if someone can make one for you.
Or you can go with a rubber hose to and move it away from you headers some.
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I havent seen one available new. If you find it anywhere new, it will be the dealer if they can still get it. Your best bet is the junkyard or ebay if you want a spare or replacement. They can still be found in great condition.
Engine: 4++,350 & 305 CIs
If you didnt know, A/C and non A/C cars use diff tubes.
non A/C doesnt have the uppwards nipple on them..
just some random info 4 ya.
This is all greatly appreciated fellas. I have removed my AC from the car and that diagram helps a lot. I think I will most likely just run some lines similar to the non-ac setup and see how that functions. Again, thanks much
Will
Will
Car: 1987 Z28
Engine: LG4
i got a stupid question, if you do the Throttle body coolant bypass you just run a line from the firewall to the lower intake manifold right?
FormulasOnly
Sep 10, 2015 09:07 PM
