Heat range (is this normal?)
Old Feb 9, 2009 | 11:40 AM
Snikker's Avatar
Car: 1998 Pontiac Firebird Trans-Am
Engine: Ls1 Modified intake magnaflow duals
Transmission: 6spd Manual
Axle/Gears: Stock
My '94 v6 has been running particularly hot for about a month now and with warmer weather on the way I want to make sure that its not going to overheat again (it already did that in 40 degree weather). The temp gauge reads from 160 to 260 degrees and runs fine (the magic 190) on the highway, but when i get off it immediately starts rise at the stoplight on the exit ramp (only stopped for about 1-2 minutes). I have a suspicion something is clogged partially somewhere, it has a fail open thermostat so if it should fail it will run cold if anything. I had the system pressure checked, flushed, and refilled at Hawks third gen about 2 months ago when my timing cover was leaking. the thermostat was replaced later that week by me (thats the last time i do that) because the other one failed. could there be a problem with my temp sending unit? The last time it overheated the heater in the car worked a little too well so it wasn't a failed thermo. but it did spew out of the overflow bottle. the mix is somewhere (this is only a guess mind you) around maybe 30 antifreeze/ 60 water combination, if that could be causing it, it's an easy fix.
This is quite befuddling to me, any input will be appreciated.
Old Feb 9, 2009 | 05:08 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
Re: Heat range (is this normal?)
did you check the air dam at the bottom of the radiator, I had one that was missing a few screws and that caused all kinds of issues.
Old Feb 9, 2009 | 07:34 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Do a compression check. It sounds like a blown head gasket to me.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
