This is What City Water Does to Your Car
Car: 1990 Chevy Camaro
Engine: 305 TBI
This Camaro has been sitting up for four years with city water in it. A given four years can do damage to any car but, it would not have been this bad if they had used distilled water...... I have a lot of work to do to this car!!!!!
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: This is What City Water Does to Your Car
you mean water mixed with coolant or just water?
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Haha,well water does that too when someone runs a car for a lengthy amount of time with just water and no antifreeve.
I had a front wheel drive car that a customer brought to me with a leaky waterpump,the guy finally got tired of adding water everyday and decided to get it fixed.
When I pulled the old w/p off the impeller was completely missing and after replacing that,I found pieces of the thermostat floating around in the lower radiator hose!
So yeah folks,don't run your car on water only in the coolant system!
It will cause damage.
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
that's why just as a precaution i use filtered tap water. i have a PUR water filter on my faucet in the kitchen- i just go and fill up a few gallons and add that to the antifreeze. you could also just get the 50/50 premix they sell.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Distilled water is not that expensive. I use that and anti-freeze 50-50.
Engine: 305 TBI
50/50 antifreeze does take the geusse-work out but do you know where Prestone or whatever company get their water from? The only way you can be sure is to mix the distilled water and antifreeze yourself. It's your motor.... It your call..........
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I've been doing 30% antifreeze / 70% water right from the hose since I got my first car almost 5 years ago and I've never had any of that crap....!!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Distilled water is super cheap.
JamesC
JamesC
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Any 50/50 combo will work fine. Almost any antifreeze has plenty of rust inhibitors that will keep your engine from looking like that. Regular maintenace is key though, it is never a fill and forget deal.
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
I was told by a pharmacist that purified water has even less contaminants than distilled water - the pharmacist also said purified water would be perfect for cooling and batteries but not people, with distilled being better for drinking. same price in gallon jugs.
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I live in FL and I have run my cars on 100% water and I have never had that problem be it with city or well water. I was a little scared with this latest cold snap we had so I put some antifreeze in but I usually don't use the stuff because water is better for cooling.
Transmission: Pro-built 700R4
Car: 1984 Camaro Z28 T-tops
A slightly lower boiling point compared to water, though water has a greater ability to absorb energy before boiling. (Latent heat of evaporation.)
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
City water purveyors have certain State Health Department regulations they have to follow. Some put more effort in water purification during production and others go for the bare minimum. Like the City where I work, the water from the tap tastes nasty. And the City I live in, it reaks of chlorine. Personally, I spend the extra bucks on distilled water for my car than take chances.
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Even if your avg coolant temp is below boiling, the local temperatures inside the engine spike well above the boiling point of water. Not having anti-freeze means the water at these points does boil and this produces a pocket of steam. This further increases the problem because now there is no direct water contact. What you get then is a combination of very hot spots forming (stressing the metal) and rusting.
Water is nearly an ideal transporter of heat, but the engine environment needs a compromise, because local temps are just too high. Antifreeze is (and there are several formulas besides ethylene glycol) the best compromise.
btw. As long as you dont have aluminum parts that your coolant goes through, your copper radiator shouldn't cause any electrolysis to occur.
Car: 84 frankenstein Z28
I think you have it backwards, with purified water being better to drink and distilled being better for batteries. True distilled water has no contaminants in it and is pure water.
Car: 1987 Camaro LT
Hell, I love my car enough that if worse came to worse, i'll throw some Evian in it.
colton_carlson
Mar 8, 2019 12:21 PM
