lower water pump hose leak?
Old Feb 15, 2009 | 01:42 PM
rock861261's Avatar
i have a 91 camaro z28 350 i have a coolant leak coming from where the water pump and the hose connect just started the hose is fairly new and i have new hose clamps and its still leaking any ideas how to fix this?
or maybe i installed the hose wrong? i have about a half inch of the water pump pipe in the hose still wont seal
Old Feb 15, 2009 | 04:07 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: lower water pump hose leak?
can you post a picture?
Old Feb 15, 2009 | 04:49 PM
rock861261's Avatar
i changed the waterpump and the hose and it stopped leaking i think it was the water pump anyways
Old Feb 16, 2009 | 06:45 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
the weep hole on the w/p is right above where up put your hose on and it judt drips onto the hose and makes it look like your claps loose just look at your pump you'll be able to tell by looking at the weep hole if it was leakin
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
