Air Filter
Old Mar 5, 2009 | 12:06 AM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Air Filter
Does putting a k&n filter right on the throttle body work better than the stock way of having the 2 air filters in the air lid?
Old Mar 5, 2009 | 11:25 AM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Re: Air Filter
No. Your two stock filters draw cool air from the outside. Mounting a filter to the throttle body will just suck hot engine bay air. Replacing your stock filters with K&N's (or whatever brand u like) and opening up the filter base is a common upgrade for the camaro air intake. Also according to your sig, your 87 will have a mass airflow sensor which would be eliminated if u were to put the filter on the throttlebody. Unless you switch to speed density your car wont run that way.
Old Mar 5, 2009 | 11:59 AM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Air Filter
Oh alright thanks man.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
Thornburg
Sep 1, 2015 03:39 AM
