check engine code 15
Old Mar 8, 2009 | 11:29 PM
Hick_101's Avatar
Howdy i had a check engine light on and i tested it and it came back code 15. Low temperature indicated at engine coolant temp sensor. what is the best way to fix this problem?? also where is this sensor located
Old Mar 9, 2009 | 01:18 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: check engine code 15
tpi or tbi? if you have the means of testing the sensor (ohm meter) then test it. if not, replace the sensor, they are like $15 bucks. on a tpi engine its located in the front of the intake manifold just above the water pump. on a tbi i don't know where its located, maybe the same place.
Old Mar 9, 2009 | 02:07 PM
Hick_101's Avatar
ok so it is a 305 tpi. i found the coolant sensor. however its not hooked up and plus I cant find the cable that should hook up to it or how it should be ran. this car has many loose wires... that i plan on trying to figure out where they go...
Old Mar 9, 2009 | 02:40 PM
QuickStyle's Avatar
Car: 91 Z28
it should come out of a loom on the passenger side of the throttle body along with a few other sensor wires (tps, iac, air, a/c)
Old Mar 9, 2009 | 02:44 PM
Hick_101's Avatar
but how is it throwing a code if it isnt hooked up?
Old Mar 9, 2009 | 03:12 PM
QuickStyle's Avatar
Car: 91 Z28
thats why its throwing a code. because its not hooked up.
Old Mar 10, 2009 | 04:29 PM
Hick_101's Avatar
ok so i re hooked up the sensor and code still on. so i went to the store and got a new one. put it on and the light is still on......should i pull the batter cable off again or any other ideas from yall? thanx for the help
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
