Help!! Over pressurised coolant system
Old Mar 30, 2009 | 12:05 PM
lispy's Avatar
Car: Firebird
Transmission: Manual
Please help me.....
I just got my '86 firebird 305ci and I'm experiencing coolant issues. The radiator had a leak when I got it so I replaced the rad with a new 3 core alloy and now after a drive out it blew a massive hole in the bottom rad pipe.
The temperature hasn't gone above half way but I have noticed a lot of pressure in the system. The oil is clean, and the water doesn't smell at all of fuel.
Any ideas?
Old Mar 30, 2009 | 10:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Help!! Over pressurised coolant system
How are you noticing pressure in the cooling system?
Old Mar 31, 2009 | 05:09 AM
lispy's Avatar
Car: Firebird
I noticed the pipes are rock solid and when the original rad was in the water was escaping with alot more force than I've seen before on a rad leak.
Also when the bottom pipe blew on Sunday it lost all of the water very quickly. To be honest it could just be just weak componets but it just seems to be a bit more than that. Are the coolant systems normally very pressurised on these cars?
Cheers
Old Mar 31, 2009 | 07:15 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Originally Posted by lispy
Are the coolant systems normally very pressurised on these cars? Cheers
Not more so than other cars/systems, although pressure will increase with higher temps. Normally the rad cap will release pressure into the reservoir first.
Replace the bottom hose and try a new rad cap. The cap should run around $5. Either that or try a pressure test to ensure your existing rad cap is venting.
Old Mar 31, 2009 | 08:43 AM
lispy's Avatar
Car: Firebird
I got a new rad cap with the new alloy rad I fitted, but I will check it. Its starting to look like the head gasket as I have noticed bubbles in the expansion tank while its running. Thanks for your help.
Old Apr 2, 2009 | 12:50 AM
Prime Target's Avatar
Car: 1984 Camaro Z28
Engine: L69
Sounds like you may have a blown head gasket. I just purchased an 84 Z28 with an L69 which I believe may also may have a blown head gasket. I get air pressure in the cooling system which bubbles over into the overflow bottle, but only after the engine is shut off. The problem didnt arise on my motor until i drove it for a while. It doesnt do it on short drives so I dont think the leak is that big. Nonetheless, going to pull the heads and do it right.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 20, 2015 06:59 PM
FormulasOnly
Sep 10, 2015 09:07 PM
TheExaminer
Sep 7, 2015 08:34 AM
