Engine temp and Air conditioner
Old Apr 25, 2009 | 05:10 PM
Phil502's Avatar
I saw a nice 86 T/A, 5.0 ,TPI, today and took it for a test drive. The air conditioner needs charging but my question is, How hot does your engine get when the air is on and you are sitting in traffic? This one was getting up to about 235 or so while air on and parked running waiting for a train to go by it may have gone higher but the train ended and I got moving again. Otherwise it ran at 210/220.
Phil
Old Apr 25, 2009 | 11:24 PM
mjsmikey's Avatar
Car: 89 Firebird Formula **MODIFIED**
Engine: 330 HP Crate 350
Transmission: 700R4 with Shift Kit
Re: Engine temp and Air conditioner
Mine has always done that. I replaced the radiator and running the air increases the temp. I think the only way to solve the problem is to buy a really good radiator or change the AC Evaporator, but i'm not expert. I originally thought it had something to do with the amount of coolant in the AC, which can cause overheating... if close to the threshold, it wasn't. Over filling, under filling... nothing, same problem.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
