Odd Cooling System Leak
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
My 86 Trans AM with a 305 TPI has developed a cooling system leak that drips somewhere off the back of the engine, and the bottom of the torque converter cover on the transmission. It is definately antifreeze leaking. As yet I have not been able to locate the source off the leak. My first thought is the heater core, but there is no coolant inside of the car. All of the hoses radiator, t-stat, were replaced a couple of years back. Here is the question. Do these engines have a component on the rear of the engine that is prone to leaks? The car has 28K miles, has miminal wear, and has not been overheated. Thanks for any ideas.
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: Odd Cooling System Leak
i had the same problem once, it turned out to be one of the hoses on the heater core came loose
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Your headgasket could be leaking externally and not internally (my dodge shadow does it). But with 28k that's not likely. Check the heater core where the hoses connect for cracks.
Alex
Alex
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Mine has rusty freeze plugs and drips at the same area, I think it's leaking above the starter and then running down and dripping off of the TC cover. It even does it when the engine is stone cold. I did put some Bars-Leaks in it and it seemed to help (temporarily).
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my waterpump gasket on the driverside was leaking and the coolant was running down the block, along the oilpan rail and dripping my oil filter and bellhousing. Check that
We found it. It is leaking between the intake manifold and the head on the driver's side. GM used silicone to seal the intake, instead of spending a few pennys on a intake gasket, and it just gave out. We are trying to get ready for the Fbodygathering in three weeks, so I took the car to a garage. Working 70 hours a week, I just don't have the time to get into a big repair project right now. Thanks for all of your suggestions.
