is stock enough?
Old Apr 28, 2009 | 11:29 PM
poomwah's Avatar
is stock enough?
I have an 87 gta minus engine... I got a hold of a 76 350 thats been bored .60 over. plans are to carb it. I have the factory radiator and the fatory dual electric fans. I've been told that theres NO way that the stock cooling system is going to keep the engine cool. I was thinking of opening up the rear vents on the 4 vent hood to let some heat out.
Is it true that the stock radiator and fans won't be enough?
Old Apr 29, 2009 | 12:11 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: is stock enough?
you have the cooling system already so dump the engine in it and fire it up. if it gets too hot shut if down and get a bigger aluminum radiator. what can be the harm?
Old Apr 29, 2009 | 12:20 AM
poomwah's Avatar
just trying to plan things out accordingly. I still have to build the engine and get a trans before I can dump it in there. LOL just trying to figure out what to expect
Old Apr 29, 2009 | 01:14 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Stock cooling system has been more than enough for my build.Its not a full on race engine but it stays 180-190* even in the hot MS summer time.I was told the same thing when I went to a 350.I just make sure it stays clean and run a 160 stat.My fans do stay on all the time for some reason.One of these days I`ll figure out why and fix it but I dont think it`s that big of a deal.Unless your going to have a radical set up I think you should be fine.
Old Apr 29, 2009 | 01:53 AM
poomwah's Avatar
thanks grady. I was having trouble understanding what the problem would be myself, didnt know if maybe the headers would let more heat into the engine bay. I figured since the car was a 350 from the factory, that the radiator would be fine for a 350, but a couple people told me because the 350 I'm going to use is bored .60 over that it will get too hot and I'll need a bigger radiator... But then again, I hear a LOT of things that don't make sense, LOL
Old Apr 30, 2009 | 07:56 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Its possible being bored may bring your temps up but Id just stick it in and see.Radiator easy enough to change.
Old May 1, 2009 | 06:14 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
coat the headers inside & out to keep temps lower
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
