Heater core welding question
Old May 7, 2009 | 05:19 PM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
I just got a new heater core and I notice that the tubes that attach to it are not very secure. I was wondering if I can get away with welding the tubes onto the heater core instead of relying on the pressed metal to hold them in place.
Attached Thumbnails Heater core welding question-img_0328.jpg   Heater core welding question-img_0327.jpg   Heater core welding question-img_0329.jpg
Old May 7, 2009 | 05:32 PM
1989birdman's Avatar
Car: 1989 firebird
Engine: 305 for now
Transmission: 700R4 for now
Axle/Gears: stock for now
Re: Heater core welding question
it all depends if its aluminum or not if its all metal you should be able to git away with it but if some thing is aluminum you mite burn threw it and if the metal is thin you mite do the same but if your takin your time you should be ok for aluminum i would use a sertin kind of welder for aluminum ok
Old May 7, 2009 | 05:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its most likely copper that plated. You can solder it.
Old May 7, 2009 | 05:45 PM
SDalt404's Avatar
Car: 1988 GTA
What do you guys think of using something like JB weld?
Old May 7, 2009 | 06:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its good stuff, go ahead
Old May 7, 2009 | 07:47 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
sure if you want to do something half a**ed.
Old May 7, 2009 | 11:14 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
A low temp solder or braze would suffice.
Old May 7, 2009 | 11:37 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
They're supposed to be able to move so you can position them better I thought.I could be off base here though.
Old May 9, 2009 | 04:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
no, they dont move
Old May 9, 2009 | 04:50 PM
SDalt404's Avatar
Car: 1988 GTA
The heater core ended up being missed packaged. So I had to get another one and the pipes were welded on the new one. ALWAYS check your parts good before modifying them
Old May 20, 2009 | 01:10 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i see you took some good pics, but i cant get an idea of actual size. can you tell me the measurements of the heater and the space it fits into?
i am looking into just using an electric heater but i have never taken mine out although i have paid someone to replace it a few years back.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
