Leaking
Old May 16, 2009 | 01:32 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Leaking
Okay well a few days ago i discovered my lower radiator hose was leaking off the bottom. so this morning i bought a new one and got it changed, ran it for a few minutes and all seemed good. But then i did a run to walmart and came out and saw coolant on the ground. Now when i got home i checked for the leak and it was still in same location as it was leaking off the old stock hose. Im out of ideas, could the new hose just be defective or am i missing something. Im pretty right now.
Old May 16, 2009 | 03:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Leaking
the radiator is leaking, not the hose
i assume you have the hose clamped properly
Old May 16, 2009 | 03:21 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Leaking
Weep hole from the water pump or bad water pump?
Try following the leak farther up, it should tell you which way it's coming from.
Old May 16, 2009 | 03:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Leaking
^what he said, another place to check. Water will run to the lowest point before dripping. My waterpump gasket was leaking and the water was dripping off my oil filter
Old May 16, 2009 | 04:31 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Re: Leaking
Water pumps are made to leak before they go out, so check there as post above states.
Old May 16, 2009 | 05:04 PM
Engine: 5.7 LS1
Re: Leaking
Thanks guys, i just read your post, and yall are right, its the water pump. i thought i had to work, when actually i didnt, and then i saw the car leaking the worst it ever has, and then i checked, i saw water behind the harmonic balancer, and it certainly was the water pump, saw i bought a new one since i was at work aka i work for advance auto parts, and im going to have it put on tomorrow. I cant believe i was blind for the entire week. yes all clamps were tight btw.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
