Why so hot
Old May 17, 2009 | 07:52 PM
84TransAm383's Avatar
Why so hot
So i just got done build my 383 and it runs super hot according to my guage. I mean 230 240 while driving but 210 idle. Its a brand new raditaor but stock size is it to small. The motor has alot of work done and the stall is 3600 with a th400 so it screams a little bit. Put electric fans on and didnt help at all. What do you guys think. I burped the system to.
Old May 17, 2009 | 09:07 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: Why so hot
Its not going to be putting off very much heat at idle.
What is your thermostat?
And do you have a coolant bypass?
Is it correct to assume you have cooling system pressure?
Old May 18, 2009 | 10:03 PM
Re: Why so hot
the stat is a 180 and the heater core and ventilation system is gone so its water pump rite into the block hose.
Old May 19, 2009 | 10:45 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Why so hot
I have similar issues. Firstly, the 383 puts out a lot more heat than stock, and the stock fans don't turn on until well over 200 degrees. Hopefully you have replaced the 195 thermostat (stock) with something cooler. But perhaps your greatest problem is you stall converter. These create HUGE heat while in gear, and this heat is transferred into your coolant via the auto trans cooler built into the radiator.
You will need to upgrade your radiator, go with a thermostat about 170 (180 max) use a cooler fan switch or just set your fans up to turn on much earlier, and remove the trans cooler lines from the radiator and run them through a dedicated trans cooler (use the "radiator" style, not the 'tubes with fins" style". If you do all the other stuff, you might not need to upgrade your radiator, but it's still gonna run hotish in traffic.
TA
Old May 19, 2009 | 11:46 AM
87350IROC's Avatar
Car: 87' IROC
Re: Why so hot
do you have the deflector in place under the radiator?
Old May 19, 2009 | 06:57 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: Why so hot
Sounds like you need a bypass.
When I turn off the valve I installed in line to the heater core it causes all kinds of strange over heating problems on the high way. Then when I open the valve, its works fine.
You need lots of coolant flow even when the engine isn't putting of a lot of heat. That keeps heat and hot spots from building up.
Plus I think the thermostat alone has trouble flowing the standard 37gpm.
Old May 20, 2009 | 08:54 PM
Re: Why so hot
I dont have the trans lines going tinto the radiatior they are on there on to a trans cooler with a fan. The electric fans are also controlled by a switch i put in so i turn it on as soon as the car starts to keep cool. The stat is also already a 180. What is the by pass you guys talk about though. I no longer have a heater core in the car.
Old May 21, 2009 | 10:49 AM
87350IROC's Avatar
Car: 87' IROC
Re: Why so hot
I repeat, do you have the plastic air deflector under the radiator installed?
Old May 21, 2009 | 05:10 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: Why so hot
You need 3 things to keep your engine cool.
1 good air flow at different speeds
2 lots of coolant flow even when not fully hot
3 cooling system pressure
If you cant control your cooling system temp you wont have any cooling system pressure at normal operating temp. If you want to be 180ish and you heat up to 230'F and cool back off to 180 you will have little if any cooling system pressure.
Your cooling system will work much better if you can keep it pressurized at you target temp.
Old May 22, 2009 | 10:23 PM
Re: Why so hot
i do not have the bottom piece for the extra radiator airflow and can not find one anywhere
Old May 23, 2009 | 12:29 AM
Camaroguy6984's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI L03
Transmission: TH700R4 Corvette servo
Axle/Gears: 10Bolt 2.73
Re: Why so hot
Ebay, i remeber seeing tons of NOS ones on there, they may still b available from GM, otherwise, Classic Industries has a camaro catalog that has TONS and TONS of repro stuff for our cars, brother bought a 69 and told me to check them for seat covers and they r the only one iv found so far that has them, not even YearOne had them last time i checked. plus the catalog is free, pick it up.
Old May 23, 2009 | 09:05 AM
oil pan 4's Avatar
Car: 89 Firebird
Re: Why so hot
I think most people who need an air deflector just make one out of what ever they have laying around.
Old May 23, 2009 | 11:08 AM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Re: Why so hot
i made an aluminum one, made it almost 2 inches shorter then the stock one and at more of am angle to the front, it was a simple fabrication job.
Old May 23, 2009 | 12:44 PM
87350IROC's Avatar
Car: 87' IROC
Re: Why so hot
Well theres your problem. Get one ASAP. Everyone sells one. Doesn't sound like you looked to hard, lol.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
