feeding the oil cooler
Old May 23, 2009 | 11:57 AM
pcfiend138's Avatar
Car: 1992 Camaro Z-28
Engine: L98 5.7L 350
Transmission: TH700R4
Axle/Gears: 3.23 7.5 10 bolt
i pulled the climate control out of my 92 z28 so now i need to figure out a way to feed the oil cooler directly from the radiator. has anyone here done this before or know how i can. im thinking about finding/making a upper hose that has a line to go to the oil cooler as well, if i can make that work would i need a regulator to reduce the pressure or would the water pump not pull enough to effect it?
Old May 23, 2009 | 05:06 PM
pcfiend138's Avatar
Re: feeding the oil cooler
i figured out how im going to do it, and now im having second thoughts since if it dosnt work id have to pull the radiator again to get the cooler lines back out. would feeding the cooler from the water pump where the heater core returned work?
tyeo098
Nov 30, 2015 06:27 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
CatmanFS
Sep 19, 2015 09:00 AM
gta892000
Sep 16, 2015 12:37 AM
apie2546
Sep 5, 2015 07:40 PM
