radiator fit issues
Old May 27, 2009 | 03:07 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
radiator fit issues
I got a "direct fit" Jegs Aluminum radiator, and it definitely doesnt fit. Called them up and they said that GM used different radiator sizes for 305 and 350 cars. I had a 305 in mine originally and he said that the 350 cars had a different lower mount. How can i make this thing fit? as of now it is too tall for the top cowl mount to bolt up. I have an 87 firebird, single stock electric fan. Thanks.
Old Jun 1, 2009 | 09:39 PM
bwtaylor84's Avatar
Car: Camaro
Engine: 350 .40 over
Transmission: TH400 TCI
Re: radiator fit issues
I bought a universal one from summit that was way too tall like 3 or 4 inches all I did was cut like 3 quaters of the bottom tray out and brace the remaining with metal stap. then went to ace hardware and bought some aluminum strap and bent them into a bracket then drilled some holes mounted the brackets loose lined them with some heater hose for protection installed the radiator tighted the brackets works great
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
