Single Electric Fan Blade Count
Old May 27, 2009 | 08:59 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
On my car, there are 5 blades on the fan. While looking on an AC Delco parts supplier web site, they listed an OEM fan with 6 blades. How many of you have the 5 blade and how many the 6?
Also, I am guessing the 6 blade would be a good upgrade over the 5. I was going to go with the dual fan set up, but since I installed the Hypertech fan switch on at 200 off at 180, with a 180 degree thermostat, i don't see the need for dual fans especially with under 220 HP. What do you think?
Old May 28, 2009 | 01:13 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Single Electric Fan Blade Count
An extra fan blade isn't really going to make any difference in cooling. Granted, the blade is designed similar.
If the 5 blade fan has slightly more pitch than the 6 blade fan, they will probably move the same amount of air.
A 6 bladed fan is easier to balance though, and make take slightly less amperage to draw the same cfm as a 5 blade fan
Old May 28, 2009 | 10:14 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Cool on the balance and the amps. I may just go ahead and buy the 6 blade fan and check out the difference. No harm in having and extra fan on hand.
Old May 28, 2009 | 01:29 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
The 6 blade fan is probably for the dual fan setup as
those fans are 6blade. I have noticed two styles of
blades for the single fans:'83-mid'85 has 5 curved,
swept-back blades,late '85-92(and into 4th gen)
has straight,paddle like blades.Both types are often
out of balance and vibrate when running,i have
balanced a few using lead tape or screws on the
outer ring.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
