86 TA Code 15 5.7 TPI
Old Jun 2, 2009 | 06:35 PM
snager's Avatar
I have a 86 TA it had a 5.0 org in it for a motor... someone put a 5.7 and I have the headaches... I'm getting code 15 and 32 I put a diff Coolant temp sensor on the drivers side, I see the one on the passingers side is plugged which I assume is for the fan... I wired the fan so it turns on as soon as the key turns on.... I put a new water pump in last fall seems fine for awhile now it acting up again. I think last year I figure the motor was like from 82 83...
looks like a new rad in it already... any ideas ??
also here is some of the numbers I got off my scanner
3rd gear sw : on
AC request : off
BLM : 128
BLM enabled : no
Coolant (f) -31
EGR Diag SW : Clsd
EGR duty (%) : 0
Engine RPM : 0
ESC counter : 0
Exhaust 02 lean
Fan Request : off
IAC position : 144
Inj pw (ms) : 0
Integrator : 128
Loop Status : open
MAF (gr/s) : 1280
MAT (f) : 64
02s (mv): 453
02s crosscnts: 0
Overdrive en : no
P/N switch : p/n
Prom ID : 8461
TCC lockup : no
TCC Solenoid : off
TPS sensor : 0.43 and 3.95
Vehspeed : 0
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
GouldyGTR
Aug 21, 2015 10:43 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
