Electric Fans
Old Jun 16, 2009 | 10:46 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Electric Fans
I am switching to a CSR electric water pump on my strip/street car and want to upgrade from the stock single electric fan. What are you guys using for aftermarket fan setups. What's are the best high cfm, low amp electric fans that fit in a third gen with a sbc and a 31x19 Griffin rad. Thanks.
Old Jun 18, 2009 | 04:32 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Electric Fans
How much cooling do you really need up there?
If you want to go dual, the GM units work OK. Duals
are intended to have staggered trigger temps, so the
control function can be a bit of a hassle. This is the
route I'm taking down here in hot S-Tex. I have a Dakota
Digital fully adustable controller, and the GM dual fans.
If those fans aren't enough, I'll get a pair of 14"
units from Summit, about 1300 cfm & $100 each.
If you want to go single, the control function is much
easier, i.e. single sensor/power relay, with some variety
of operational range sensors available. For a single
unit, I'd want at least 2000 cfm cabability.
There's a direct correlation between CFM & amps. So plan on
a relay circuit.
Good luck, ayh.
(How do you spell that???)
Old Jun 19, 2009 | 03:43 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Re: Electric Fans
I ended up picking a Flex-A-Lite 420 eh. 2500 cfm and 22amps. I will just put it on a switch like my old setup...the car is mostly just for the track but is street driven (the street out to the track...). http://www.summitracing.com/parts/FLX-420/
Thanks for the reply, eh.
Old Jun 19, 2009 | 04:16 PM
Re: Electric Fans
Good to go, eh.
Check out Kevin McClelland's column in the Aug. issue of
Chevy High Performance magazine, re. cooling fan current
draw. I don't know what kind of switch you have, but
check the rating of over-the-counter switches.
22 amps @ 12 volts is a good bit of power, needing
at least 12 ga., preferably 10 ga wire. Relays are
really cheap, compared to electrical fire repair.
Okay, I checked out the link -- high end DUAL fans,
on a single switch. You sure suckered me in on that one.
Old Jun 21, 2009 | 07:16 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Re: Electric Fans
Yeah,my electronics are are all wired through relays.
Old Jun 21, 2009 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Electric Fans
22 amps! holy crapnuts! I have a pair of perma cool fans, 2950cfm each under 10 amp draw.
Old Jun 21, 2009 | 07:44 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Electric Fans
that cant be right.
the factory single fan is 25 amps IIRC
22 amps sounds about right to me.
Old Jun 22, 2009 | 03:47 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Electric Fans
Originally Posted by RED_DRAGON_85
that cant be right.
Hmm...
http://www.summitracing.com/parts/PRM-19115/
Old Jun 22, 2009 | 09:28 PM
Re: Electric Fans
Yuze guys, eh.
Hoser must be sittin up there drinkin beer, and thinkin
"What a buncha moose-heads eh."
Old Jun 29, 2009 | 06:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Electric Fans
Don't know about stock factory single fan, but the Autozone/Advance replacements are only 11.5 amps
Old Jul 6, 2009 | 02:04 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: Electric Fans
What do you guys think of these:
http://cgi.ebay.com/ebaymotors/PROCO...Q5fAccessories
Here's my car btw:
https://www.thirdgen.org/forums/nw-i...re-bought.html
Thanks!
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
