86 cooling question
Old Jun 19, 2009 | 04:40 PM
buzzmeup's Avatar
Car: 1986 Camaro
Engine: 350-4bbl-Edelbrock Headers
86 cooling question
Purchased 86 camaro 350-300 hp, headers, cat-back exhaust, elderbrock intake,summitt 600 cfm carb., 700R4 trans, not sure of gear. I am quite sure it has the orgin. electric cooling fan on it. Undernormal driving temp runs 180 to 190, I have a manual switch for the fan. Ran the car 3 or 4 times hard thru 1st and 2nd gear last nite up to about 65-70 mph. Temp went up to 220 and when I shut it down up to 245. I want to replace the fan with one that has a internal switch to activate the fan. What CFM should I use and is there anything I can do to get more air thru the front clip. Thanks
Old Jun 19, 2009 | 06:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 86 cooling question
these cars breath and cool from the underside. THere is, or should be, an air damn mounted to the bottom of the radiator support, sticking down a few inches. It has to be there.
As for fans, the more cfm's the better. 3000 should be more than enough. I use 2 3000 cfm fans, one on a manula switch, the other on the factory fan switch.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
