i just found out that my air dams missing
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
the junkyard has some but they take forever to lift the cars up 2 get one. so can anyone give me the dementions to make one? i also need to know what angle it sits at. i figured out my overheating problem by the way. i deleted the ac and the condenser looked like some one took a hammer and flattened all the ribs. now she hardly touches 220. Alotta you guys should check out your condensers if you have overheating problems.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: i just found out that my air dams missing
you could always spend 30 bux anbd get a new one.
As for making one, just slightly angled forward is fine, so long as its strong enough not to bend. 3 or 4 inches high would be enough.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1992 Camaro RS
Engine: 305 TBI
I probly will just break down and buy a new one but Im curious if thaeres a way to fabricate one that will work better thatn a stock air dam. Just as a little side project. Who knows, maybe Ill come up with somethin good.
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I'd make one myself. The factory air dams don't work well enough as far as I'm concerned.
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
the factory ones are perfectly adequate. Something else is causing your car to overheat, ie: component failure, installation error etc
Well, it's not exactly overheating, but I have a 180 thermostat in it, and it goes up to the first line w/o the fan. With the fan, it goes down a bit.
eightsixseven
Dec 16, 2024 01:50 PM
kyle5647
Aug 15, 2015 11:56 PM
