Fan problem
Old Jul 9, 2009 | 04:42 PM
90 RS Camaro's Avatar
Fan problem
90 Camaro RS Fan will only work with A/C on. I disconnected wire from fan switch in passenger side cylinder head and grounded it with key on and no fan. Checked fuse under dash it's good. To check the fan relay my repair manual said to install a jumper between terminal A (black/red wire) to terminal E (red wire). Fan came on, so I replaced the relay, still no fan. Checked the ground at the fan, it's good, checked for 12v at fan and nothing. I know the new relay could be bad but not likely. Am I missing something. Need help. THANKS
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
