a/c controls
Old Jul 17, 2009 | 09:30 AM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
a/c controls
Not sure if anyone else gets this problem, but lately its been getting worse. I'll turn on my a/c to "MAX" and it will blow through the defroster first~then the front vents. The time between the switching is increasing every day. I used to start the car, put my bag in the back seat, get in and it be frosty. Now, I make it 3 blocks down the street before it blows through the front vents.
Old Jul 17, 2009 | 02:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: a/c controls
Usually these issues are vacuum related. There is a vacuum line than runs to the controls - the vent routing 'doors' are operated by vacuum - whena position on the switch is selected, the vacuum is rerouted to open or close that 'door'.
Check to see if there is anything like a kink in the vacuum line, or a loose vacuum connection on the back of the controls, or a cracked vacuum connector on the controls, etc. You may need to get a new set of controls if the housing on the back where the vacuum gets ported is cracked.
Old Jul 17, 2009 | 02:55 PM
monkihead's Avatar
Car: 1990 RS
Engine: 305 TBI
Axle/Gears: 3.08
Re: a/c controls
Good call. Nothing was cracked or kinked, but played with it and found a leak. As I'd put under "max" the rotating disc would seperate just enough to let out the vacuum. Bastard plastic...
Old Jul 17, 2009 | 03:11 PM
Car: 1992 RS
Engine: Carbed 350
Re: a/c controls
Glad to help.
junior419
Apr 7, 2025 11:35 AM
Nervous2
Oct 8, 2015 10:53 PM
RacerM
Sep 28, 2015 04:25 PM
Mdenz3
Sep 17, 2015 08:36 AM
85Special
Sep 3, 2015 04:21 PM
