Temp and stalling
Old Jul 25, 2009 | 07:10 AM
mlcobb's Avatar
Car: 1984 Black Trans Am with 15k
Engine: 305, V8
Transmission: Stock
Axle/Gears: Stock
Temp and stalling
Randomly my third gen trans am will overheat and then stall but not on a consistent basis. I did a two/three radiator flushes (highly recommended for those of you with an original radiator). I replaced the thermostat. It stays at 180 for about a half and hour then will start creeping up to the 220 mark. After theat when I see it creeping to the 220 mark and then come to an eventual stop the car will stall. I can restart it with no troubles but the same thing will happen. Any thoughts, ideas? I will repalce everyhting related to these problems if I have too. I just need a checklist of things to look for. Thanks in advance!
Old Jul 25, 2009 | 01:53 PM
mecham84's Avatar
Car: '84 Trans am ‘86 Iroc
Engine: 305 auto, 305 auto,
Transmission: Automatic
Re: Temp and stalling
Not sure if this will help, but I live out in AZ so cold is not really a factor. I put in a 160* thermostat in my 1983 trans am, and flushed everything. Now my car doesn't go over 200* ever and runs perfect, and we are having 112* days! Also make sure your front lower deflector is bolted on right, those are a must to force air into the radiator.
Old Jul 25, 2009 | 02:13 PM
BigO's Avatar
Car: 89 IROC-Z
Engine: 5.3
make sure your cooling fans are operating but your ecm will ont kick them on until the 230 mark.
sheachopper
Jul 31, 2019 11:27 AM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
