higher temp
Old Aug 3, 2009 | 07:47 PM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
higher temp
i have a 350 non computer controlled carbed engine in my 88 iroc. it always ran about 190 degrees. I did a topend rebuild on it and did not reconnect the heater core. My car now runs between 220 and 240. Does anybody have any ideas why? could it be because I did not hook up the heater core?
thanks in advance
Old Aug 3, 2009 | 08:28 PM
kcb37's Avatar
Re: higher temp
Did you change anything other then the heater core?
I can see a temp drop with a heater core as opposed to without, as the coolant is basically going thru a second radiator. However when the heat is off, the coolant dosen't circulate thru the heater core. So it really shouldn't make a difference.
Old Aug 4, 2009 | 06:42 AM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
Re: higher temp
yeah i made a few changes. I thought they were for the better. I put in a new intake, carb, dist, headers,waterpump,ps pump and alt.
Old Aug 4, 2009 | 09:42 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: higher temp
Your timing could be off,carb running lean,or have the wrong water pump .
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
