homemade ac delete
Old Aug 17, 2009 | 09:26 PM
83RDRACR's Avatar
homemade ac delete
Here is pic of ac delete I made for '84. I cut the evap case off as far from the blower motor as I could to get a flat surface to build on. I made an aluminum backing plate from .095 thick sheet and paterned it after the stock ac housing. The ductwork from the blower motor to the opening in the firewall was made from 22ga aluminum. the duct work tapers in depth from the blower motor case (about 3") to 1.25" .
The blower motor case and ductwork were attached to the heavy aluminum backing plate with rtv sealer and pop rivets. The backing plate gives it support and allows it to be fastened to the oe heater box inside.
To get rid of the industrial looking pop rivets, I applied a thin coat of dura glass. This not only improved its looks but provided a layer of protection to the thin aluminum and a little insulation from the engine and exhaust heat.
I'll have more pics next week of the finished unit and the modified interior heater box.
Attached Thumbnails homemade ac delete-ac-delete-box.jpg   homemade ac delete-modified-heater-case.jpg
Old Aug 17, 2009 | 11:28 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: homemade ac delete
Could've boughta actual delete box but holy **** dude you got some good metalworking skills!
Old Aug 18, 2009 | 12:31 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Very nice.
Old Aug 18, 2009 | 06:41 AM
one92rs's Avatar
Car: SOLD!!!!!
man that is nice. ill be sending you mine here pretty soon.
Old Aug 18, 2009 | 09:38 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Is that gonna be an all out race car? I see you got some plans on the gauge cluster, and in the 2nd pic it looks like you got a kirkey laying inthe car too. Awesome work man
Old Aug 22, 2009 | 05:46 PM
83RDRACR's Avatar
It could be. The car was a roller, totally gutted, no engine, trans, interior, or wiring. Pretty much just a shell. I built the car for my son and since he fancied himself as the next Jeff Gordon it took on a sort of stock car flair. Kirkey's. Roll bar. Simpson 5pt harnesses, custom aluminum dash with toggle switches and aoutometer gauges. Heck, we even pulled the font of the fender well out so we could fit 275-60-15 tires on 4" bs wheels all the way around.
any way here some finished pics of the ac delete box.
Old Aug 22, 2009 | 06:02 PM
83RDRACR's Avatar
Here is pics of seats, dash and heater box.
Old Aug 22, 2009 | 08:26 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Looks Great!! I hope your son appreciates it.
I got the ultra lite gauges too, and man you must have 400 in gauges alone lol. looks sweet
Old Aug 22, 2009 | 10:06 PM
cutmesomeslack's Avatar
Car: 1984 GMC. soon to be 1986 camaro
Engine: Carb'd 350
Transmission: TH 350
Axle/Gears: Stock
very nice!! that dash looks great. I wish I could make a heater box like that for my car.
Old Aug 23, 2009 | 10:12 PM
Deweywolf's Avatar
Car: 1989 RS
Engine: 350 TBI
Transmission: 700R4 by Monster transmition
Axle/Gears: Borg warner 3.08 posi
Where does one buy a delete plate?
Old Aug 23, 2009 | 10:22 PM
Deweywolf's Avatar
Car: 1989 RS
Engine: 350 TBI
Or would you make and sell another plate?
Old Aug 26, 2009 | 01:45 PM
mattmerritt89's Avatar
Car: 1987 Camaro
Axle/Gears: 4.56
Does the blower still work in it. I was thinking of making one for my car. Also, how did you get a template off of the original box?
Old Sep 7, 2009 | 05:37 PM
83RDRACR's Avatar
My son decided not to keep the heater in the car, opting for the smooth firewall look, so this unit is available. Its been stored for a while. let me check it out to make sure all the blend doors still work and we'll work something out.
Old Sep 7, 2009 | 05:52 PM
83RDRACR's Avatar
the blower and blend doors all worked off the stock heater controls. you can see the resistor block for the blower speeds mounted in the duct work just left of the blower motor. The heater controls allowed you to choose between defrost and floor vents and between fresh outside air or heat.
to make the template I just took the entire evap case off the firewall and laid it flat on a piece of poster board and drew around it. Once I had the basic shape and the location of the blower inlet and the firewall heater box opening I designed the ductwork to transition from one to the other, keeping it as flat and compact as i could and still have adequate air flow.
Old Sep 7, 2009 | 06:09 PM
Deweywolf's Avatar
Car: 1989 RS
Engine: 350 TBI
You looking to sell the one you made?
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
