overheating with a/c on
Old Aug 20, 2009 | 12:03 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I have replaced everything in the air conditioning
when I am driving without stopping the temp seems to stay normal
as soon as I get into town in the stop and go traffic the motor starts to overheat
my dual fan setup works just fine and I have a brand new radiator
I was thinking of putting a fan on the outside of the condenser and having it push air through
the air deflection shield is fine
is it because the motor is 60 over with 10:1 compression
any help would be great
Old Aug 20, 2009 | 08:56 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: overheating with a/c on
I was having the same problem. The issue is that the a/c condenser mounts in front of the radiator and when the a/c is on that condenser gets hot and fans are pulling all that hot air through the radiator raising the coolant temp. You said you have a new radiator. Is it a stock radiator or aftermarket? The factory radiator should be good enough for stock to mildly modified engines but if you're making more hp(400+) then you're gonna need a bigger radiator preferabbly aluminum two or three core. I bought a 3 core aluminum on ebay and now I don't overheat in traffic with the a/c on.
Old Aug 21, 2009 | 10:56 AM
jamon8's Avatar
Engine: 350 tpi
its a stock radiator
so you think the fan on the condesor will not work
Old Aug 21, 2009 | 05:27 PM
pwdbychevy's Avatar
It should help since you're not overheating while driving. You might have an issue trying to find a place to put it because of the x support braces.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
