cooling issue?
Old Aug 25, 2009 | 08:07 PM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
cooling issue?
ok so my car is shutting off at 220. the fans arent turning on, the fuse is good and i replaced the relays. wats next to look for? please help.
Gary
Old Aug 25, 2009 | 09:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: cooling issue?
If the car is shutting off as in no running at 220, then it's alot hotter than 220, so don't trust your guage anymore. These cars are designed to run at that temp. Sounds like a bad fan switch - located in pass side head, between #6 & #8 plugs. Take the single wire connector off by squeezing it at the ridges, then poke a wire in there and ground it with the key on, and see if the fan comes on then. If it does, replace the switch - watch the coolant, you'll get a face full - you'll have to add more after the swap.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
