fan question
Old Sep 4, 2009 | 08:37 PM
mark 87gta's Avatar
Car: 87 trans am gta
Engine: 355 ci
Axle/Gears: 327 for now work in progress
fan question
i got an 85 trans am 377 sb i got rid of the ecm cause i went with a carb how would i wire my fan up on a toggle switch do i need a resistor or anything any help would be thankful i have it wired now to run with the ignition but it keeps melting fuses
Old Sep 5, 2009 | 05:21 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Re: fan question
Mark, if memory serves me right you can tap into the green/white striped wire at the fan relay and connect it to a toggle. That should ground the relay and turn on the fan manually. Since you are not connecting to a power wire, no more fuse problems and no resistors needed.
Old Sep 9, 2009 | 12:24 PM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
Re: fan question
for $30 at Pep Boys you can get a wiring harness for up to two fans, relay, and adjustable dial from 80* and up! I say, save yourself the head aches.
Old Sep 9, 2009 | 06:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fan question
That's what I did with mine - I wired in a seperate fan controller because I always had issues with the factory fan switches going bad, and I got tired of getting a face full of coolant everytime I had to replace the switch. But I used a more expensive Flex-a-Lite controller that has provisions for switches and such. It was easy to install, has a probe for the radiator to get temp, fully adjustable, and has worked great for 3 years now.
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
