GOT ME STUMPED A/C
Old Sep 23, 2009 | 01:23 AM
Richwiz1's Avatar
GOT ME STUMPED A/C
I have a 91 z28 350 tpi my problem is one fan wont come onand compressor wont shut off. I checkeked fan motor is good. PUT some freon in it still didnt work replaced high side switch no go replaced cycling switch didnt work. the compressore wonj shut off even with control in off position only way I can get it off is to unplug switch mounted in compressor. any help appreciated
Old Sep 23, 2009 | 12:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A/C Not 2 B
Check your HVAC panel’s compressor switch.
It might be broken and locked in the closed position.
As to the fan you need to find out if it’s the “normal” one or the one associated with the AC.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime or if there is a little rain!
Old Sep 23, 2009 | 05:06 PM
Richwiz1's Avatar
Re: A/C Not 2 B
The is the one associated with the a/c can bypass high pressure switch and it will run. T he other switch your talking about where is it located ?
Old Sep 24, 2009 | 12:41 PM
NINÅ's Avatar
Transmission: 765R4
A/C Not 2 B
The switch I’m talking about is the one you access from the cockpit when you turn on the A/C or front defrost.
Use a meter to make sure it’s operating properly.
Happy Racing!
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Mdenz3
Sep 17, 2015 08:36 AM
