So I'm driving down the highway...
Old Sep 23, 2009 | 09:28 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
after replacing my heater core. I'm feeling real proud so I pump up the heat even though its already pretty...darn....hot out but I just needed to bask in my glory. I'm cruisin' and decide I've had enough heat and turn it off. I get to the stop light and steam comes rolling out of every open hole from the driver forward (hood, fenders, anything) I pull into the gas station, add some coolant add some water and temp goes a little below normal but eventually goes to where it should be, no worries all the way home. (I did check the heater again when I got about a mile away from my house, no issues) When I get home I took off the plastic plate that goes under the box where the heater core is and I see some coolant. it doesn't make sense to me. Fresh new heater core, hoses were hooked...could it be that because I didn't add coolant right after putting in the new core too much pressure built up from the heat?
Old Sep 24, 2009 | 07:45 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: So I'm driving down the highway...
Everything mass produced has defects. If it does it again and your sure its the heater core its time for an exchange. Just make sure everything is tight like hose clamps and such next time you go for a ride and see what happens.
Old Sep 24, 2009 | 11:46 AM
Mr Froman's Avatar
I was afraid of that answer : ( Thanks I will try it.
Old Sep 28, 2009 | 10:20 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
did you turn the heater on full blast when you first adding coolant after finishing the heater core job? Could have experienced china syndrome...
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
