AC Compressor
Old Sep 24, 2009 | 12:09 PM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
AC Compressor
Right now my ac isnt charged, but i was wondering if i charged it if it would work because my ac condenser in the front the fins are very weak and fragile and crumble apart when touched. Is this normal for the condenser or is this a problem?
Old Sep 24, 2009 | 01:05 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Rule The Cool
You don’t mean “compressor” you mean “condenser” and yes you will derive an A/C performance increase if you replace that dirty old benty finned front thing.
Because there is no freon in it it’s the best time to do it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Sep 25, 2009 | 09:48 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: I Rule The Cool
Those condenser fins are what sheds the heat from the system. The more heat they shed, the colder your A/C will be. (Remember air conditioning isn't about making things colder. It's about removing heat and only having cold left over)
They shouldn't crumble in your fingers. I've heard that Proliance makes a direct fit 6 mm picallo condenser that is better than the stock tube and fin....Parallel flow condensers are the best performers. But as far as I know, require custom lines to connect to our systems.
Galaxie500XL
Feb 1, 2020 04:53 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
