fire bird fan not working
Old Oct 13, 2009 | 07:34 PM
luckytempo93's Avatar
well the title is a lie. i have a 91 firebird and just did a 305 to 350 swap and for some reason my cooling fan will not come on unless i turn on the a/c. and i am still using the 305 computer and wiring harness. engine runs fine. and also are there 2 thermostats? one for the computer and one for the guage? cause the guage does not work either.
Old Oct 13, 2009 | 11:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fire bird fan not working
Single fan?
Was TBI or TPI?
I'm going to assume 305 TBI...
Did you install the fan switch from the pass head of the 305 to the 350? If not - that is you issue with the fan - the fan switch is in pass head between #6 and #8 cylinder, with a 1 wire connector. When the temp gets hot enough, the switch activates the ground for the fan relay and activates the fan.
If there is no provision for this on the 350, or it's plugged on the 350 and you can't or don't want to remove the plug, may I recommend a seperate fan controller from Flex-a-lite - Summit sells them and they are great! Has a probe that inserts between the radiator fins to sense temps, is fully adjustable for on temp and off temp, has provisions for manual on switch in the interior, and mine is 3 years old and works everytime perfectly.
There is another coolant temp sensor located on the driver side head, between #1 and #3 cylinder (on the 305) that will also have a single wire connector - this is the one that sends signal to the guage. Locate this on the 305, and see if you can't swap it to same spot on the 350 - that will solve your guage issue.
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Leggman1
Aug 6, 2015 04:15 AM
