Removing Cooling Fan Switch. 91 Z 5.7
Old Nov 7, 2009 | 01:39 PM
shingadaddy's Avatar
Car: 91 Z.
Engine: 5.7 TPI
The high temp switch in the passenger side head. The single wire connector won't plug back onto it. I think the internal connection in the switch may be dammaged / bent. So I need to get it out to see.
I get to it. Moved the dip stick. Remove+ from battery then moved connection wires on starter out of the way.
I have the 22mm wrench on it. Great tight fit. When I put removing pressure on the wrench it turns the outer nut face but the center part of this switch that the wire plugs into is not turning with the outer nut.....
Anyone had this happen? I'm a little spooked at whats happening here. Please, any wisdom/advise appreciated. I'm taking a breather for a bit to see if anyone can help.
An help / experience appreciated please.
Thanks all.
Old Nov 7, 2009 | 04:42 PM
Car: 91 Z.
Engine: 5.7 TPI
Re: Removing Cooling Fan Switch. 91 Z 5.7
Okay so it was my eyes and the short stroke I was getting on it. Its out. And I suppose it was turning from the begining.
Here it is
http://www.autozone.com/autozone/cat...uestid=3763368
Anyone got a good lead on mating connectors for these??
Oh and of course the connection was fine so no telling what was going on while I was trying to plug it back in. But the connector is busted so I need a new one. DOH!
Old Nov 7, 2009 | 05:41 PM
Car: 91 Z.
Engine: 5.7 TPI
Mine did not have all the plastic hood like this one does. Maybe mine was broken off. Does anyone recognize this
http://cgi.ebay.com/ebaymotors/90-92...item29f812667d
as the one that fits the switch I posted earlier??
Old Nov 7, 2009 | 08:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
looks like it to me
Old Nov 8, 2009 | 08:48 AM
Car: 91 Z.
Engine: 5.7 TPI
Thanks. I'll get one and give it a try.
Old Nov 14, 2009 | 10:04 AM
Car: 91 Z.
Engine: 5.7 TPI
EFI connection for the connector part and back in with the perfectly functional switch. Back in business...
z28addict8490
Sep 5, 2015 03:56 PM
Ducati900ss
Sep 2, 2015 09:05 AM
JHX
Aug 29, 2015 02:30 PM
3rdgenparts
Aug 8, 2015 07:09 PM
Leggman1
Aug 6, 2015 04:15 AM
