use 4th gen radiator shroud with LS1 dual fans???
Old Nov 7, 2009 | 11:15 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
For those of you who are using the LS1 dual fans, did you hack up the 3rd gen radiator shroud to fit the fans, or did you buy a 4th gen shroud? Or maybe I should ask if the 4th gen shroud even works first.
I went to install the LS1 fans I bought and hacked up the shroud when I realized how difficult the "simple" mod really was. I'm thinking about getting a 4th gen shroud if I see that others have had good experiences with them. Thanks!
Old Nov 8, 2009 | 08:21 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: use 4th gen radiator shroud with LS1 dual fans???
you mean like these.
not sure how much room you have between the steering gear and the radiator. mine was a little tight so i had the space the motor in and modify the shround for the fan on that side
this was the first try to give you an idea. i have since gotten another fan shroud and redid it with smaller mods.
Old Nov 8, 2009 | 08:24 AM
one92rs's Avatar
Car: SOLD!!!!!
here i just trimmed the top piece that ended up fitting perfect.
here is a pic of where mine is close to the gear
on the top i used 1/8X3/4 strips to mount it.i bent them over the top of the radiator and put a screw in the back. and i have one strap on the bottom.
hope this gives you the answer you were looking for. i used a flexalite controller for mine. i suppose you have the harness already set up with a 6.0 swap. and man do they cool the car down to.
Old Nov 8, 2009 | 12:43 PM
BlueZee28's Avatar
So is that a 4th gen shroud, because it kind of looks like how I chopped up my 3rd gen one haha. I am using the stock 3rd gen radiator too.
Old Nov 8, 2009 | 01:29 PM
one92rs's Avatar
Car: SOLD!!!!!
those fans came from a 2001 camaro. and that is my stock third gen radiator. as far as i know the third gen fans did not have a shroud. i know the lt1 cars and up had these shrouds.
Old Nov 8, 2009 | 02:24 PM
BlueZee28's Avatar
The shroud I'm talking about is the black plastic piece that covers the top of the radiator and bolts to the frame. Is the one you're using from a 3rd gen or 4th gen?
Old Nov 8, 2009 | 04:06 PM
one92rs's Avatar
Car: SOLD!!!!!
ahh. that is the one from my third gen. i trimmed the piece off of it that held on my single fan. put them in buddy. they work great. i just wish that the left side fan was the one mounted higher.
Old Nov 8, 2009 | 08:32 PM
BlueZee28's Avatar
I'm going to borrow a friend's radiator shroud from his LS1 car and see if it works. I have a feeling it might not, because I believe their radiators are shorter in length, but I will post up results regardless. If I have to do it the way you did it I will, but I was hoping to not have to use a hacked up shroud.
Old Nov 8, 2009 | 08:57 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
ls1 fans and radiator fit great.
i use a modified lt1 top piece to hold it all in like stock.
will need to modify for power steering.
will clear a manual box just fine.
Old Aug 17, 2010 | 01:25 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Just wondering if u could post pics of what u ended up doing? I have a third gen radiator and I am going to switch to a 4th gen radiator and I have a set of '97 Z28 fans I am going to use. Thanks.
Old Jul 10, 2012 | 02:35 PM
92RS4US's Avatar
Car: 92 25th anniversary edition
Transmission: 700R-4
Axle/Gears: 2.73's
maybe this could be a sticky? I would like to swap my stock single fan for dual fans too. Seems getting fans off a 4th gen would be more cost effective? pics would be nice too!!! any help on this would be greatly appreciated!!
The Arizona heat is making my RS run around 220+with the A/C on
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
