Fan Isn't Working!
Old Nov 24, 2009 | 09:39 AM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Fan Isn't Working!
Yesterday I noticed the temp on my car going up really fast and I pulled over and I noticed the fans weren't on. I checked the fuse and it was good, but there was a clicking sound coming from the relay for the fans. I bought a new relay and it wasn't that either. You guys have any other ideas on what it could be?
Old Nov 24, 2009 | 10:04 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Plan
If the fan or fan circuit has a short it can cause a voltage drop in the circuit which makes the relay drop out.
Test the fan by applying 12 volts (thru a 30 amp fuse) to it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Dec 4, 2009 | 07:37 PM
99transamgirl's Avatar
Car: 84, 99 Trans Am
Engine: 305 G, LS1
Re: Fan Plan
I had my fan motor go out once. I could hear a noise and sometimes it would work very slowly and finally went. New motor from the parts store for about $25 fixed it. That could also be an option.
Old Dec 4, 2009 | 08:22 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: Fan Isn't Working!
Turn on your air conditioner, the fan should run with the air conditioner, if it does its not the fan motor, since you replaced the relay, i would guess the fan switch, or possibly the relay you bought is bad to begin with, it happens unfortunately. Good Luck!!
eightsixseven
Dec 16, 2024 01:50 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Reddeath210
Oct 6, 2015 08:20 AM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
