Ext. Tranny cooler connections
Old Dec 15, 2009 | 02:51 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Hi all,
I am hoping to get some ideas from you. I have an external tranny cooler that I have to run with my new transmission. I am going to be running it in series with the OE cooler built into the radiator. When connecting things up, I wasn't satisfied with the way the kit connected to the OE lines, going from steel to rubber.
I was hopping you could post some photos as to how you have your cooler connected into your lines if they are anything different from how the kits instruct you.
THanks
Old Dec 26, 2009 | 10:15 PM
hotbird89's Avatar
Car: 90 Trans Am
Engine: 5.0 TPI- slightly modified...
Transmission: Modified 700-R4
Axle/Gears: 10 bolt 3.23 eaton posi moser shaft
Re: Ext. Tranny cooler connections
All aftermarket kits come with rubber. As long as they are routed and protected properly all will be fine.
IF you are determined to use steel- you will need the proper fittings and pipe. Route it around the passenger side of the radiator between the A/C condenser and the filler panel. Keep the bends simple and ensure that you use a tubing bender. Otherwise the tubing can crimp and reduce flow- which would definately not be good...
apie2546
Sep 20, 2015 01:03 PM
gta892000
Sep 16, 2015 12:37 AM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
