Temp gauge not working!!!HELP
Old Jan 10, 2010 | 01:44 AM
Dany89's Avatar
My temp gauge seems to no be working were is the temp realay. what could it be, how can i fix it???
Old Jan 10, 2010 | 07:14 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Re: Temp gauge not working!!!HELP
Most likely your temp gauge sender has either become disconnected or the sender is bad.
The sender is located between cylinders 1 & 3 on the driver side head. You will see a brass sensor with a black end. You should have a wire that comes off of the same part of your harness that connects to your oil pressure sensor and O2 sensor. If no wire it attached than you need to find it and put it back on. If it is still attached than the sender needs to be replaced. You can get them at any auto parts store for about $6.
Hope that helps!
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jk_Under
Aug 17, 2015 03:08 PM
bamaboy0323
Aug 15, 2015 07:20 AM
