AC condenser
Old Jan 11, 2010 | 09:07 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
AC condenser
is it safe to buy these used? also are these needed for the car to run or are they just for the A/C?
Old Jan 11, 2010 | 11:05 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: AC condenser
Shouldn't be a problem. The old tube & fin style condensers on our car are easily flushable. They're only needed if you want to run A/C.
Old Jan 17, 2010 | 12:16 PM
Engine: L31 350
Re: AC condenser
thank you
Old Jan 19, 2010 | 05:36 PM
Engine: L31 350
Re: AC condenser
just ordered mine from thirdgen ranch, anything you guys would suggest i do before i install it?
Old Jan 21, 2010 | 02:11 PM
Engine: L31 350
Re: AC condenser
bumb
Old Jan 22, 2010 | 03:29 PM
knapper79's Avatar
Car: 84 Trans AM
Engine: 355 SBC 400HP 427TQ Custom Build
Transmission: TH350 current, swapping to 700R4
Axle/Gears: GM 10 bolt, Auburn Posi 3.73
Re: AC condenser
Are you doing all the work yourself or taking to a shop? If you are doing all the work, you should always flush a used condensor core off of the vehicle using A/C flush chemicals. Always follow the direction with the chemicals since different ones require different procedures. Then make sure you evacuate all flush solvent, then let dry in a clean area. Then install, making sure your fittings are clean and free of any debris. Use new o-rings on anything on your A/C system that has been distrurbed. Lube new orings before final assemly with PAG oil rated for your system (depending on if you are using R12 or 134A).
Then are you charging the system yourself?? You first have to pull a complete vacuum on the system. I like to let it sit with a vacuum pulled, machine off, for about 30-60 minutes and see if it changes. If there is a change, it is an indication of a leak. If you suspect a leak, you can charge with a small amount and user a sniffer to detect or inject die and use a UV light.
Once you are satisfied that there are no leaks, do full charge and run a performance test. Thats the basic way way/explanation.
I am guessing you do not have to equipment or experience to do a full A/C service. So instead, when you take the vehicle into the shop to have them charge it, have them run a leak test as well. Let them know you replaced the condensor with a used unit and anything else on the system you might have done, it will cut their diagnoses time in half should there be any problems with your system.
Old Jan 25, 2010 | 07:00 PM
Engine: L31 350
Re: AC condenser
ill be installing the condenser myself this summer, but ill prolly have a shop charge it and run all the test on it,... one my question how would i go about storing this till summer? i heard that if you get water in the system that when i go to install it in the summer it would be hard to get all this water out so how would i go about storing this for a few months
Bubbajones_ya
Jul 6, 2024 08:32 PM
b4ccamaro
Jun 5, 2016 01:48 PM
my86bird
Oct 23, 2015 12:20 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
