No blower motor at any speed
Old Jan 12, 2010 | 11:36 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
I am trying to get this HVAC stuff figured out after the LSx swap and I can't seem to get the blower motor to work on any setting. Low/Med/High all show nothing on a multimeter attached to where the blower motor would plug in.
I have good voltage at the large red wire (constant hot). As mentioned though the purple wire has no voltage, both at the relay and the blower end. It does not appear to be a ground issue, I used the chassis as a ground for it via the multimeter probe.. Interior controls do have voltage from both feed wires.
What would cause the purple wire to show no voltage, does this sound like a control issue?
Old Jan 13, 2010 | 12:19 AM
$750 L98's Avatar
Re: No blower motor at any speed
I noticed something. On the first 2-3 speeds I do see about 2-2.5v on the purple wire, 0v on high speed. That is using a multimeter grounded through the chassis, not the ground wire on the blower connector.
Old Jan 13, 2010 | 12:21 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
yeah I think you need a ground wire from blower case to chasis ground in case you didn't have that. Sounds like you have a switch issue. you have voltage on low med but not high....does the fan blow on low med now?
Old Jan 13, 2010 | 12:38 AM
$750 L98's Avatar
It does not, even when plugged in the blower doesn't move at low/med. I am going to try tomorrow using a ground to chassis WITH the blower hooked up and see if it is a ground issue. Plenty of power at the controls, but it doesn't seem like i am getting much of anything at the blower itself. 2.5v wouldn't even be enough for low/med would it?
Unfortunately the multimeter broke and no longer works for testing continuity or I would know if the grounds are good. The only way I could test the ground was to use the chassis as a ground on the ground probe, and then test the voltage I got with the red probe in the hot side of the circuit - the purple wire. (which showed the 2-2.5v for the purple wire).
Old Jan 13, 2010 | 01:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
It’s Good 2 Blow
It sounds like you have no voltage going INTO the speed switch.
It’s the
BROWN wire going to the switch
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
soarestransam
Sep 1, 2015 04:00 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
