car runs too warm
Old Jan 26, 2010 | 04:34 PM
supermariobros's Avatar
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
car runs too warm
Well I have a 89 formula 5.0 TPI and it gets a little too warm, it will creep up to almost 3/4 and then drops back down to half but it only does it at idle and it also surges and runs lean. I've replaced the thermostat, and did a coolant flush anything else I should do? I'm thinking that maybe my fans are coming on a little too late any ideas? I was thinking about adding a oil cooler but I dont really wanna dump anymore money into this set up.
Old Jan 26, 2010 | 05:59 PM
87_ta_305_4bbl's Avatar
Car: 87 Trans Am
Engine: 305 4bbl
Axle/Gears: 10 bolt 3:52
Re: car runs too warm
first you need to figure out why your car is running lean because if your car is running lean not only will you have surging but also running lean causese your engine to run a little bit warmer i would check sensors and all that jaz if all that checks out you might look into getting some new cooling fans from your local auto parts stor the electric ones are pretty cheep and very reliable just some ideas
Old Jan 26, 2010 | 06:34 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
The fans don't come on until the car gets pretty hot in the first place. Also,
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
mustangman65_79
Aug 8, 2015 12:07 PM
