Engine runs cold/No heat
Old Jan 17, 2010 | 07:27 PM
pgh1992's Avatar
Car: '92 Camaro
Engine never gets past 130 in summer or winter. I replaced the thermostat, the temp sending units, and had the ECU replaced, but it still stays at 130. The fans still run normal. My heat was working for the past few weeks, but it stopped working. I replaced the thermostat again with a 195 , that fixed the problem and i got heat for a few days then it cut out again. Need some help
Old Jan 17, 2010 | 07:31 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: Engine runs cold/No heat
this sounds strange, but try turning your temp to cool instead of heat. I did that the other day, and the temp guage went from rock bottom to medium
Old Jan 17, 2010 | 07:36 PM
pgh1992's Avatar
Car: '92 Camaro
I actually tried that the other day, no difference. Temp stayed the same no matter how long i drove the car. Not worried about the heat so much, just wanted to know if it was bad for the motor to stay that cold.
Old Jan 17, 2010 | 07:39 PM
58mark's Avatar
what happens when the car idles for a long time after it's been driven for a bit?
Old Jan 17, 2010 | 07:44 PM
pgh1992's Avatar
Car: '92 Camaro
Nothing it runs fine, smooth idle. The temp might go up about 5, but still no heat.
Old Jan 18, 2010 | 08:17 AM
yyanna2's Avatar
fab info..have been looking forward it
Link Building
Old Jan 18, 2010 | 12:45 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
disconnect the wire on the fans. run the car and see if it heats up (with a/c off and heater off), if it does get hot like normal than maybe research more into thermostatic fan switch i would think, anybody agree? When done with the test dont forget to reconnect the wire to fan. btw laser thermometer are good investments to double check the temp, , Would by chance youre using Mr Gasket thermostats?? because it sounds like a thermostat to me
Old Jan 21, 2010 | 04:26 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
My car does the exact same thing. I disconnected the fan and it ran up to temp. like it should. When I turned it off to plug fan back in it sounded like it was about to boil over. Once the fan took over it went back down to 130 degrees. What to do now?
Old Jan 21, 2010 | 04:47 PM
replace your fan switch, http://www.autozone.com/autozone/cat...&parentId=63-0 7 bucks, its between the 6-8 cylinder. careful will the connector on the switch/sensor, its so brittle mine broke and i had to solder a new connector to the harness. you should be golden after that. Part # SW502 at autozone (for 1988 chevy camaro 5.0L
Attached Thumbnails Engine runs cold/No heat-temp.jpg
Old Jan 21, 2010 | 05:19 PM
Engine: 350 S/B
Thanks alot TransAm85. I'll try that.
Old Jan 24, 2010 | 03:44 PM
Engine: 350 S/B
Is that easier to get to from the top or bottom of the car?
Old Jan 24, 2010 | 03:57 PM
F-Body Demon's Avatar
its gonna be easier from the top
Old Jan 26, 2010 | 12:04 PM
Engine: 350 S/B
I don't even see this switch, too much crap in my way. Is it on the cylinder head?
Old Jan 26, 2010 | 12:23 PM
its on the block, right above the knock sensor. i had to get underneath. you can feel it. imagine the 6th and 8th cylinders spark plugs, now in the middle below about 6 inches. one wire Check this link out http://www.superchevy.com/tech/0502s...ing/index.html it kinda helps.. What brand t-stat are you using?
Attached Thumbnails Engine runs cold/No heat-0502sc_cool_11_z.jpg
Old Jan 26, 2010 | 08:34 PM
Engine: 350 S/B
That's an interesting link Transam. Might take that into consideration as driving in Texas gets a little warm.
Old Jan 26, 2010 | 09:00 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Ok, that link says they put a chip in the computer... I know the computer is what tells the fans to switch on because of the temperature of the sensor, but does the lower temp sensor tell the ECM to turn the fans on or does the ECM need that chip to recognise it?
Old Jan 26, 2010 | 09:42 PM
rojas1826's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
my fans always stay on and i cant figure out why.
Old Jan 26, 2010 | 09:46 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
The fan relay may have a direct ground on it, instead of being grounded by the ECM.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
