Cooling a 406
Car: 84 15th Anniversary Trans Am
Engine: built 406
Axle/Gears: 3.73 10bolt
Cooling a 406
I'm currently looking for a cooling system upgrade. Radiator, Fans, Thermostat, and oil cooler. I drive my car to work most days, however in the summer in July and August(Myrtle Beach, SC) it gets into the lo 100s and the car starts running too warm for comfort so I have to drive my Camry, Blah!....Same as if I'm running alot of runs at the track.
Current setup is stock with 160
Anyone have some suggestions from your setups? Obviously cheaper is better, but I can spend some money if need be, PAY TO PLAY!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Cooling a 406
you are still using the stock radiator i assumne?
i would get a larget alumin radiator, like the ones summit/jegs sell as "direct fit" replacements. They are a bit larger and you need to modify the upper radiator plastic support thing. a new high flow fan, or a dual setup would be good too. i would put a 180 degree stat in it, 160 is usually too little, and get a new fan switch to turn the fans on around the 180 degree mark.
then just make sure the lower air dam in there and in good shape.
if you want an oil cooler, just make sure you use at least 1/2" lines and the system has to be thermostatically controlled
Car: 84 ta
Engine: 406
Transmission: th 350
Re: Cooling a 406
i also have a 406 in a 84 ta i have modifed the radiator sopport to fit a 19x31 radiator out of a 70s pickup i had to cut and drop it 2 inches but it fit between the frame rails i have no ac.This rad is a 4 core. I put on a 7 blade clutch fan instead of those little one ment to run 305s hot for emmissons. that with a bottle of WaterWetter made by redline this runs my 406 around 195 on the hottest of illinios days. 11.15@124
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Cooling a 406
Since this is a Camaro, and not a truck, you won't have it heavily loaded (ie making heat) for a long enough time to need real cooling system modifications (ie radiator).
Driving to work your engine won't need to work hard enough to make a lot of heat. I'm guessing you're in stop and go traffic, and still using a belt driven fan? I'd upgrade to an electric fan. The ones from the Ford Taurus are fantastic. I only use the low speed setting.
And yes, the air-dam is the most crucial part of it.
Engine: built 406
Re: Cooling a 406
The air dam is good, I do have a belt drive fan. and stop go for about 15minutes. I'll have to look into those tuarus fans. thanks
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: Cooling a 406
I have a summit direct fit aluminum radiator, be cool dual 11" fans, electric water pump all on toggle switches, air dam and the moroso plate restrictors instead of a thermostat on my 600hp 383 and it does not go above 180 on real hot days. Usually 160 is the norm.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Cooling a 406
And yes those air dams are extremely important.
Car: '86 T/A
Engine: Vortec 406sbc-carbed
Transmission: 700r4-vette servo/B&M shift kit.
Axle/Gears: Ready to splode
Re: Cooling a 406
I'm about done building my 406. It's taking the place of a destoyed LG4(previous owner) and i'm wondering how cooling will be since all the cooling parts are stock but functional 305. I'm going to try to get the best water pump I can afford at the moment but wanted to ask for reassuance. And what about these Taurus fans? Are they direct fit/plug n play? What year/model would I need?
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Re: Cooling a 406
I run a stock radiator and a taurus fan on my 406 with a 160 t-stat. 6.70's in the 1/8th on spray and can drive it to work every day if need be. That fan is the ticket. $35 from the bone yard.
Car: '86 T/A
Re: Cooling a 406
That's good to hear. How does it go in? Bolt in and go or will I have to fab somehing up? And what Taurus does it come out of?
Car: 1982 Trans-Am
Re: Cooling a 406
Mid '90s. Mine is from a '95 I believe. I think the 3.8L ? It might not matter actually.
The stock cooling system is fine. Keep in mind during cruise and whatnot you're not making much more heat than a 305 anyway. The only reason to upgrade your cooling system is if you're doing some track racing. Otherwise you won't be making major heat for long enough to outrun your stock cooling system.
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Re: Cooling a 406
It's from an early 90's taurus with the 3.8 engine. If you do a search on the fan on this site you should find a ton of info on it.
