Help.. not too sure
Old Feb 3, 2010 | 09:52 AM
TiffnDs's Avatar
Car: 83 Chevy Camaro Z-28
Transmission: 5-speed manual
Axle/Gears: standard
Help.. not too sure
OK. I got an 83 Camaro Z-28, and Im not sure what it is, but when I turn my heat on the fan makes weird noises, and I can only use the defrost part to heat the car.. Does anyone have a clue what it might be and how I might be able to fix these issues.. Thanks
Old Feb 3, 2010 | 09:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Help.. not too sure
Welcome to TGO. A search on site is always useful (there's not much that hasn't been discussed on more than one occasion). Defrost is the default if there a vac leak. The usual culprit is the switch itself. Put an ear the control head and give it a listen. The noise? Could easily be a motor going out. It is 25+ years old after all.
JamesC
Old Feb 3, 2010 | 10:06 AM
TiffnDs's Avatar
Thanks so very much. It is an old car, but I LOVE IT....
Old Feb 3, 2010 | 10:10 AM
JamesC's Avatar
Oh, boy--get ready to spend some money .
JamesC
Old Feb 10, 2010 | 04:55 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Ditto the welcome.
If the fan noise is like a squeeling, than it is probably the motor.
If it's like a clattering, than it's probably dirt/trash in the blower
chamber. The fan is servicable from the engine compartment, but
I don't know how hard it is to get to, with hood/fender in place.
JamesC's advice is correct as often as Rush Limbaugh (99.+%)
If the dash controller is bad, the vacuum router (which directs cabin
air flow) is definitely the weakest link -- and it's gonna be PITA to service.
Bless you for nurturing & keeping the breed alive.
Old Feb 10, 2010 | 04:59 PM
bowtieboy42's Avatar
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Theres also a flap that directs air after it passes the heater core. Its right under the passanger side dash. I would imagine the sound is coming from the blower motor itself, which is the big box right under the hood on the pass side against the firewall.
Mshrmhd
Feb 27, 2003 10:57 PM
BOTLFED
Jan 31, 2003 02:57 PM
Kj Rockz
Jan 18, 2003 05:33 AM
telstar
Jul 15, 2001 11:11 PM
83_TA
Jun 21, 2001 07:13 AM
