Can i change my water pump?
I am moving around my belts and pulleys. I am fortunate enough to have been able to remove my smog pump and the A/C went out of there with it, so i have a shorter serp belt now. Last week i broke the crappy alt/ps bracket and now i'm looking into some nicer ones. Problem is that they wont work with the reverse rotation pump. Can i use a standard rotation or must i stay with the reverse? THanks
Re: Can i change my water pump?
I found my answer... On a mustang site
. But it will work. Just going to have to change my pulleys to V belt... Unless there's a ribbed WP pulley out there for us...
. But it will work. Just going to have to change my pulleys to V belt... Unless there's a ribbed WP pulley out there for us... Supreme Member
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
with chevy you will have to change pump to STD.
rotation if you use v-belt pulleys(different bolt pattern
anyway) IIRC ford has straight impeller blades on their
pumps which will work either rotation,while chevy has
curved blades and will pump poorly running reverse.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
