running hot
Old Mar 19, 2010 | 07:02 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
running hot
ok well i had a problem with my waterpump its just give up on me
so went to get a other on had a friend put it in he cracked the pulley idk how but he did so i went to the junkyard and got one off a 3500 v6 bolt right up since the A.I.R is out had to get a other belt 918k6 worked great put a 180 themo in and flush the coolant and fulled it with dexcool got it for cheap so why not that was in dead winter now it like 60-70 degrees the car heats up in less then 8 mins and when i'm in traffic the fan is always on i was just wondering would the bigger pulley off the 3500 do this or the dexcool ?
because i remember it being 80-90 degrees and my car would take forever to hit 220
Old Mar 19, 2010 | 08:32 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: running hot
Had to read that a couple of times to understand it. Its like one long sentence. Is the pulley smaller or bigger than the original?
Old Mar 19, 2010 | 09:02 PM
Car: 1992 firebird
Engine: V6
Re: running hot
well its form a 3500 v6 Chevy motor it's much bigger not buy alot but noticeable
Old Mar 20, 2010 | 07:15 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: running hot
if the pulley is any bigger, its going to slow down your water pump, and give you much less flow. Look into buying a stock replacement pulley on either summit or jegs.
theshackle
Mar 5, 2017 06:37 PM
BADNBLK
Nov 16, 2016 09:12 AM
ezobens
Aug 19, 2015 10:29 PM
jackhammer
Aug 15, 2015 10:04 PM
