proper way of filling dry radiator/cooling system?
Old Mar 25, 2010 | 07:02 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
hey guys, I was just wondering if there are any proper ways to fill a bone dry radiator in my 91 Trans Am... I reinstalled the waterpump, radiator, over flow tank, and all the appropriate hoses since I had them off while doing work to the car. Sorry if this is a dumb question, but I thought I'd ask and be safe than sorry!
Thanks!
Old Mar 25, 2010 | 07:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: proper way of filling dry radiator/cooling system?
Take the cap off, fill the rad, start the engine, keep topping up the rad with coolant as the level goes down. When the level stops going down and the coolant starts to spill out the neck as it heats up, put the cap on and fill the reservoir to the cold mark.
Old Mar 25, 2010 | 07:33 PM
Engine: LB9
You nailed it... thanks!!
Old Mar 25, 2010 | 08:00 PM
F41eatsFords's Avatar
just for anyone else who reads this for their own fill-up, place an asprin (yes, the ACTUAL BRAND NAME asprin tablet) in the thermostat to hold it open. this allows all the air to escape from the system so no air pockets form. you also don't have to run the engine til operating temp, because the stat is already open. once coolant hits the pill, it disolves with no adverse affects on the system.
Air pockets are more common on Fords and other makes, but I found with my carbed V8 that if done the normal way, it started dieseling when I tried to shut it off. Using the asprin resulted in no dieseling.
Old Mar 25, 2010 | 08:11 PM
Engine: LB9
oh wow good idea. I'm actually glad that you reminded me about the thermostat regardless. Thanks!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Numbah-1
Sep 12, 2015 08:57 PM
TheExaminer
Sep 6, 2015 11:40 PM
