Barely any air from vents
Old Apr 9, 2010 | 05:13 PM
THEGunboundGod's Avatar
Car: 1986 Z28
Axle/Gears: 4.11
I'm getting barely any air from my vents, even when it's turned on high. I just replaced the heater core, and the panels that move when you change it from vent, heat, and defrost all moved fine. The blower motor sounds like it's blasting loud on high, but I'm not getting much. Any ideas? Should I take the blower motor out and see if it's clogged?
Old Apr 9, 2010 | 05:58 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Barely any air from vents
It's possible that you obstructed a door(s) when you replaced the core. That said, the motor is over two decades old, I assume, so it can't be as efficient as it once was.
JamesC
Old Apr 9, 2010 | 06:04 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
i have a similar problem. What helped was checking all of your vacuum connections under the dash, especially the one that is on the far right of the passenger compartment near the door
I helped mine, but it's still weak. It's on high, but it feels like medium.
Old Apr 9, 2010 | 08:50 PM
Car: 1986 Z28
Axle/Gears: 4.11
Are the vacuum tubes easy to replace?
Old Apr 9, 2010 | 08:52 PM
58mark's Avatar
well I found one that was disconnected...
Old Apr 9, 2010 | 08:56 PM
JamesC's Avatar
If there's a vac problem, the default will be defrost. If all functions work, then the problem lies elsewhere.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
